Configures the Web server target in the XML client.
target | Specifies an alpha numeric string that identifies the configured target. |
url | Specifies the Web server URL. |
vr_name | Specifies the virtual router over which the XML client process can connect to a Web server to send push notifications. |
user | Specifies the alpha numeric string identifying the Web server user. |
encrypted-auth | Specifies the encrypted user authentication string. |
queue-size | Specifies in numeric format, the size of the buffer that stores incoming events from ExtremeXOS software. |
N/A.
Use this command to configure the Web server target in XML client process.
The following command configures the target target2 for the user admin:
configure xml-notification target target2 user admin
This command was first available in ExtremeXOS 12.4.
The virtual router option was added in ExtremeXOS 12.4.2.
